Missing transmission values
Covers v8 mustangs in 99-early 01 years. Can be configured for V6 easily and cobras as well as trucks and other fords if hardware is compatible.
glhs
Vehicle Information: 1999 Ford Mustang Cobra, ZMR2 ecu, 10:1 4.6l forged w/terminator heads, Procharger D1SC, Sullivan lower and HPP upper intake, 120lb injectors, Versafueler, Magnafuel 750 fuel pump, return style fuel system, BBK long tubes, built 4R70W w/manual valve body and reverse lockout, solid rear axle swap w/3.73 gears, Moates QH, Tuner Pro RT
Unread post by glhs »
I'm working on making a base tune for my 99 cobra and for the bin file I'm trying to use EPM2_256 but cannot find SW_STALTV or FN616F. Could they be labeled under something else or am I doing something wrong? I've played around with tuning fwd turbo dodges in the past but this is my first time tuning a Ford and it's a much larger learning curve. Any help is greatly appreciated.
Re: Missing transmission values
cobra has manual trans
glhs
Mine was swapped to a 4R70W with a manual valve body by the previous owner and I was thinking this bin file was my best choice since it was for a gt auto.
manual valve body is a manual transmission the ecu does not control it
what are you trying to do?
glhs
Sorry for the late response. I bought the car but I've had troubles finding someone in my area that can tune the car. Fast forward 11 years, I want to get this car out so I figured I'd just learn how to tune it myself. That way when ever I decide to do more mods I can do it myself. For now I just want to be able to start the car, move it around, and make sure there are no leaks with hopes to start pushing it next year.
Unread post by red5.0fogger »
pushing it???
glhs
WOT, push the motor to redline, see what the car can do
I thought I knew what you meant. That said the cars been sitting a while, ( push power). So it's push power now, you need it running to drive so you can start pushing it again.... I'm just messin at this point. It's all good.
90TbirdSC
Vehicle Information: 1990 Thunderbird SC auto, stock for now. Have an ECM w/harness and 4R70W trans for future swap from a 2000 Mustang 3.8L
Ranger Super Cab STX 4x4, stock for now. Have a 5.0L w/ecm, harness and 4R70W trans for future swap from a 2000 Mountaineer AWD. Also have a 1999 Mustang Cobra ECM if usable
Unread post by 90TbirdSC »
Can a Cobra computer be reprogrammed to run an auto or is it not hardware supported?
