Perload switch
Posted: 2023 Jun 19, 09:23
by SOAB_465
I'm not able to find the PRLDSW scalar in the CRAI8 xdf, does anywone know what to search for?
There's no FN035, but FN035A is properly populated with maximum load at 0"vac/0boost. Load at WOT goes up to ~1.42, but perload never exceeds 1.00 in the datalog.
The MAF curve is dialed in well, but I'm not getting enough power enrichment under boost, and I don't want to tear into the base fuel table if I can easily fix PERLOAD to go into the part of table it should be using.
Re: Perload switch
Posted: 2023 Jun 19, 11:49
by red5.0fogger
On the foxbody it's a flag, not in scalars.
Re: Perload switch
Posted: 2023 Jun 19, 14:35
by SOAB_465
Thank you! I was definitely looking in the wrong spot, but it's also not listed in flags, so I'm still not sure what I should do with my perload situation.
Re: Perload switch
Posted: 2023 Jun 20, 06:19
by red5.0fogger
I know it will take a while but just look at everything. Read the comments as you hover of them. Hopefully the Decipha himself will assist soon.
Re: Perload switch
Posted: 2023 Jun 20, 09:47
i hadn't put the prldsw flag in there
the crai8 xdf is very basic for now
Re: Perload switch
Posted: 2023 Jun 20, 11:13
by SOAB_465
oh ok, it's running fine, but the MAF is still calibrated up to get enough fuel in boost. I guess I just need to understand what the perload logic is so I can set up the fuel table properly. Right now perload clips at 1.00
Re: Perload switch
Posted: 2023 Jun 20, 15:16
that means its using inferred load prldsw==2
info is in the fuel write up
you wont have access to it til i can get around to add it
Re: Perload switch
Posted: 2023 Jun 20, 15:28
just posed a new xdf for you
enjoy
Re: Perload switch
Posted: 2023 Jun 20, 15:37
by SOAB_465
man you've been one one today! Thanks for all your help
