Perload switch
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
- tuning with TunerProRT
PLX Wideband
GM 3bar MAP
Perload switch
Unread post by SOAB_465 »
I'm not able to find the PRLDSW scalar in the CRAI8 xdf, does anywone know what to search for?
There's no FN035, but FN035A is properly populated with maximum load at 0"vac/0boost. Load at WOT goes up to ~1.42, but perload never exceeds 1.00 in the datalog.
The MAF curve is dialed in well, but I'm not getting enough power enrichment under boost, and I don't want to tear into the base fuel table if I can easily fix PERLOAD to go into the part of table it should be using.
Re: Perload switch
Unread post by red5.0fogger »
On the foxbody it's a flag, not in scalars.
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
PLX Wideband
GM 3bar MAP
Re: Perload switch
Thank you! I was definitely looking in the wrong spot, but it's also not listed in flags, so I'm still not sure what I should do with my perload situation.
Re: Perload switch
I know it will take a while but just look at everything. Read the comments as you hover of them. Hopefully the Decipha himself will assist soon.
Re: Perload switch
i hadn't put the prldsw flag in there
the crai8 xdf is very basic for now
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
PLX Wideband
GM 3bar MAP
Re: Perload switch
oh ok, it's running fine, but the MAF is still calibrated up to get enough fuel in boost. I guess I just need to understand what the perload logic is so I can set up the fuel table properly. Right now perload clips at 1.00
Re: Perload switch
that means its using inferred load prldsw==2
info is in the fuel write up
you wont have access to it til i can get around to add it
Re: Perload switch
just posed a new xdf for you
enjoy
SOAB_465
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
PLX Wideband
GM 3bar MAP
Re: Perload switch
man you've been one one today! Thanks for all your help
