http://www.efidynotuning.com/idleair.htm
Sometime in the next year I will be revamping the idle air write up amd will be rwmoving the tidbits on simplifying idle air to commanded target iscdc table and such.
It works great and when its dialed in its perfect but its time consuming and requires a bit of knowledge on the end user. Its also not applicable to 05+ powerpc 11+ tricore and newer bosch.
Base tunes will all be getting updated as well and instead suggested typical airmass values will be given for typical engine sizes.
[Idle Air Write Up]
Re: Idle Air Write Up
Posted updated idle air write up. Last updated 2016.
