Couple questions
Posted: 2023 Apr 09, 15:44
Been working on getting fuel dialed in on the 98 cobra which is pretty close up to about 400 AD counts but I noticed at the 200 AD count range, I am getting about a 3% variance between the -1 and 0 columns in the histogram. I have about 250 samples in the -1 and 250 in the 0 column so I would assume they should be close to each other. There are a few other ranges that show the same thing but there are only a few samples in either column depending on the location many in the other column so in that scenario, I just trust the column with significantly more samples.
Second question, ive noticed while idling, the car seems to overshoot stoich when switching back and forth from lean to rich but it only seems to happen at idle. While driving, it seems to respond much faster and I never see it drop into the low 14s or into the 16s. The car seems to over correct AFR when switching back and forth. Example, The car is at 14.3 and switches to calling for lean and it will jump to 15.2, then ill see 14.1, then 15.5, 13.9to16.3, then it seems to settle down and fall right back to around stoich then repeat. When it does this, the car sounds like its got a very slight surge that gets more noticeable as the AFR swings are larger. Is there a way to minimize the swings?
