MZAK0 Question
Can be used on all 99-04 5.4 and V10 Heavy Duty F Series Gassers.
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
MZAK0 Question
Unread post by Cougar281 »
Is this another custom strategy like the FBGI0 strategy, that can be used on all PCMs used on 99-04 F-250's, but with an appropriate base file (I'm assuming that's the case, but I've been wrong before)? The reason I ask is I just read my friends 99 F250 SuperDuty v10's PCM with PCMFlash, and it turns out the strategy of the read file is MAAG4, which obviously, when opened with TunerPro, things didn't line up.
Re: MZAK0 Question
yep no problem toss the VMA2 file in her
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Re: MZAK0 Question
Attached is the stock file as read by PCMFlash.
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Re: MZAK0 Question
Wait, sorry, I just realized that I totally mis-understood.
I just realized that the VMA2 is your file for the MZAK0 definition. :facepalm:
Is that a 1:1 MAAG4:MZAK0 that can be dropped straight in and run exactly the same as the originally read calibration without tweaks to get it to run right?
Re: MZAK0 Question
yep its a stock file juat load it in
if using pcmflash youll have to swap the banks and clear the filler
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Re: MZAK0 Question
Great, thanks!
