Page 1 of 2
ZYA2 not work?
Posted: 2022 Dec 05, 11:55
by Red Mach1
Hello. I tried write zYA2 into my mach1. After write complete(pcm flash), fuel pump ticking with ignition on. I tried identicication button in my pcm flash, pcm flash display error on vin and strategy, immo light on, radiator fan activate with ignition on, sym2 same problem but AMZ_stock, MGZT_stock works without problem. I only insert vin and pats code into all bins.I was not tried start car...
Attached picture from amz2 write...on zya2 is ERROR status at strategy and vin location...
Re: ZYA2 not work?
Posted: 2022 Dec 05, 15:01
bin has to be 224k for pcmflash to write
you need to tune it with tunerpro and the qh first before you write it
Re: ZYA2 not work?
Posted: 2022 Dec 05, 15:50
by Red Mach1
256k bin open in tuner pro, insert vin amd pats after closed tuner pro was convrted to 224...with amz2 works
Re: ZYA2 not work?
Posted: 2022 Dec 05, 19:00
the code at 1319b is all corrupted
Re: ZYA2 not work?
Posted: 2022 Dec 05, 19:49
by mechanicalmatch
Are you using tool from custom ecm solutions to swap the banks?
Re: ZYA2 not work?
Posted: 2022 Dec 05, 22:40
by Red Mach1
Yes. Picture attached higher.
Re: ZYA2 not work?
Posted: 2022 Dec 05, 22:50
by Red Mach1
decipha wrote: ↑2022 Dec 05, 19:00
Wrongly converted to 224?
How I can fix it?
78?
Re: ZYA2 not work?
Posted: 2022 Dec 06, 02:02
your missing a ton of code. You have to put the missing code back in.
Re: ZYA2 not work?
Posted: 2022 Dec 06, 05:14
by Red Mach1
decipha wrote: ↑2022 Dec 06, 02:02
Code lost after converter convert bin to 224? Converter not work properly? I Need used another converter or manual bank swap? Couldnt you convert 256 to 224 right way for my please? I will compare, search differences because now I dont have idea where code missing...why code lost. SORRY for many questions.
Re: ZYA2 not work?
Posted: 2022 Dec 06, 05:45
by Red Mach1
Couldnt these problems here for reason I not have US regional setting in my pc, binary editor works only if pc set on US regional setting in windows.
