ECT Payload
ECT Payload
Im working with the FBGIO strategy on a 2003 Mach1. The temp gauge on the dash is reading correctly but the payload on the dashboard in tunerpro is reading -214. I checked the transfer curve and compared it with two different bins and it looks normal. Any ideas what might cause this?
Re: ECT Payload
Did you enable the dma datalogging patch?
Re: ECT Payload
I believe so. I'll check when I get to the garage. Everything else seems to be working. It is showing FRP fail and STALL on the top right side of the dashboard. I'm also getting a #2 injector fault flag. So I'm not sure if all of these things are related.
Re: ECT Payload
I didnt have patch enabled.
