i was looking thru an 03 cobra file in HP tuners and thought it would be nice to have the options to disable all these fault codes in tunerpro. i had an idea on a way i could help with that. let me explain my idea
-read "stock" bin with pcm flash
-edit file in hpt, flash to eec-v
-read with pcm flash again, and use a hex editor to compare the 2 files and find the offset of the byte that changes, document and repeat process for all available DTC.
would this be of help to you to further develop XDF''s?
fbgi0-more dtc options?
CVAF1
4R70 3.08
Re: fbgio-more dtc options?
nope not needed its much faster to just find the p-code switch in the code
CVAF1
4R70 3.08
Re: fbgi0-more dtc options?
Ok, it is more reading and studying till I can do that.
