03/04 Mach 1
03/04 Mach 1
Unread post by bad86capri »
I know you say (ALL) in description but which strategy would i use for the 4 valve mach 1?
Re: 03/04 Mach 1
Let me clarify. Are the tunes the same between the GT and the Mach?
Re: 03/04 Mach 1
FBGI0 covers 2001.5 - 2004 Mustangs V6 GT Mach-1 Cobra Manual and Automatics
No, the tunes are not the same. Regardless you will have to dial it in.
best bet for a mach though is to become a premium member as high compression 4v's can be pesky with timing and dashpot.
Re: 03/04 Mach 1
i must be blind because i cant the fbgio bin in the downloads. Am i overlooking it?
Re: 03/04 Mach 1
its at the top with the adx and all
amz2 and mgzt you can pick either
Re: 03/04 Mach 1
So another crazy question. im used to tuning the GUFB. Do the 03 04 cars have factory wideband o2s or are they narrow band?
Re: 03/04 Mach 1
narrowband same as the foxes
the front widebands are 2011+
Re: 03/04 Mach 1
So the mach i have is a 03 with 97 Mark VIII shortblock fresh built and set of 04 9 thread heads. The only thing ill really need to tune for is the 90mm lightning maf and longtube headers. Would i better off getting a SCT handheld or using my QH?
Re: 03/04 Mach 1
BTW im completely new to the mod motor game.
Re: 03/04 Mach 1
sct is garbage for the older vehicles. QH is the only way to go.
yeah you definitely need a remote tune
