Datalogging with K-constant other that 30
Posted: 2022 Jun 29, 20:50
"ADX K-Constant Dependency
Furthermore the K-Constant must be set to 30 lbs/hr for datalogged values to display correctly. RWHP, RWTQ, AirMass, Fuel Flow amongst almost everything my adx self calculates in tunerpro is based on the K-Constant not changing i.e. remaining "constant". So as you can infer changing the K-Constant will change the entire foundation of the tune."
When datalogging a tune with K-constant other than 30, what needs to be done to make the datalogging more accurate? What are the concerns?
