Datalogging with K-constant other that 30
DOHCTOR_32V
Vehicle Information: 95 Cobra
Unread post by DOHCTOR_32V »
"ADX K-Constant Dependency
Furthermore the K-Constant must be set to 30 lbs/hr for datalogged values to display correctly. RWHP, RWTQ, AirMass, Fuel Flow amongst almost everything my adx self calculates in tunerpro is based on the K-Constant not changing i.e. remaining "constant". So as you can infer changing the K-Constant will change the entire foundation of the tune."
When datalogging a tune with K-constant other than 30, what needs to be done to make the datalogging more accurate? What are the concerns?
Re: Datalogging with K-constant other that 30
nothing can be done hence why its a constant
no concerns really just the SP_ values displayed wont be accurate
tune wise not having the k constant at 30 will reduce resolution so you wont have as accurate fuel control
DOHCTOR_32V
Got it. Thanks
