[OMAE2] Strategy Files
Posted: 2021 Mar 02, 13:48
EKO2 - 2002-2003 harley and lightning.
Note: EKO1 is the 2002 harley which uses the older strategy OMAE1 instead but is directly swapped out with EKO2. Same goes for the lightning catch codes which can be swapped out with EKO2 just update the gear ratio and tire size.
Re: [OMAE2] Strategy Files
Posted: 2021 Sep 16, 11:25
Attached my stock tune file from my harley truck.
Posted: 2022 Apr 13, 08:50
Just added HLODH to prevent power enrichment lambse being commanded on closed loop re-entry which causes an excessive amount of time to return to stoich after exiting wot or when stabbing the throttle.
Posted: 2022 Jul 05, 14:33
updated xdf posted
Posted: 2022 Aug 18, 17:18
I simplified iac multiplier to target iscdc but theres a n-d air modifier causing iac to 0 out on transitions. Will be adding it with the next update.
Posted: 2023 Nov 13, 12:45
new xdf posted with added parameters
Posted: 2024 Dec 13, 22:42
