EKO2 - 2002-2003 harley and lightning.
Note: EKO1 is the 2002 harley which uses the older strategy OMAE1 instead but is directly swapped out with EKO2. Same goes for the lightning catch codes which can be swapped out with EKO2 just update the gear ratio and tire size.
[OMAE2] Strategy Files
- OMAE2_241213.xdf
- previous from 23-11-13
- (629.43 KiB) Downloaded 2132 times
- DECIPHA_220505d.adx
- OMAE2 selected
- (398.31 KiB) Downloaded 2756 times
- Stock_EKO2_256k.bin
- (256 KiB) Downloaded 3213 times
Re: [OMAE2] Strategy Files
Attached my stock tune file from my harley truck.
Just added HLODH to prevent power enrichment lambse being commanded on closed loop re-entry which causes an excessive amount of time to return to stoich after exiting wot or when stabbing the throttle.
updated xdf posted
I simplified iac multiplier to target iscdc but theres a n-d air modifier causing iac to 0 out on transitions. Will be adding it with the next update.
new xdf posted with added parameters
