Is the 2-step patch functional in RZASA?
I wanted to make sure I understand how it works. The comment says it changes the neutral rev limit to the stationary rev limit based on the OSS, so anytime VSBART_RT < TQ_VS_MAN then the neutral rev limit would be active?
And will it cut the spark or fuel, or retard the spark after TDC?
2-step patch in RZASA
csmach1
- Vehicle Information: 2003 Mustang Mach1
Vortech supercharger
FBGI0
1997 MarkVIII
Turbo running CMAI6
Re: 2-step patch in RZASA
Yes
yep
fuel, only my eec-iv 2 steps are ignition cuts. EEC-V is a bit more involved to do so.
yep
csmach1
FBGI0
1997 MarkVIII
Turbo running CMAI6
Sweet, Thanks. I'll give it a shot once I get switched over to RZASA
cool, what vehicle are you swapping over the mark 8 ?
csmach1
FBGI0
1997 MarkVIII
Turbo running CMAI6
Yes, the mark 8 is running your RZASA now. I was having some trouble with the 2 step patch, but haven't had much time to look into what was going on. Seemed like it was still using the neutral rev limit for park/neutral only. The car is still in the air right now, once I get it back on the ground I plan to look into this a bit closer.
