Do the old SD ECUs have PWM fuel pump control? if not will the coyote fuel pump work without it?
Other recommendations?
Fuel Pump Options
Re: Fuel Pump Options
no and yes
Nope, the coyote pump is the way to go.
thanks, that said where do you source the pump itself? I assume I will be just replacing the pump and keeping the rest of my stock assembly.
Yeah having a hard time finding just the pump without the assembly.
I don't believe you can get it without the assembly. You can order it off rockauto. If you want just a pump the AEM pumps are decent quality as well.
