Motorcraft Wiring pigtail kits ID guide
Posted: 2022 Jan 10, 22:29
by mechanicalmatch
Motorcraft connector and pigtail catalog.
connectorcatalog.zip
(2.3 MiB) Downloaded 1278 times
added BWD connector illustration 1/18/22
bw11211-illustrated-connector-guide.zip
(3.04 MiB) Downloaded 1398 times
added circa 2005 motorcraft connector pigtail info 8/3/22
Wiring_Pigtails_Catalog (1).pdf
(755.69 KiB) Downloaded 1346 times
Wiring_Pigtails_Buyers_Guide.pdf
(2.98 MiB) Downloaded 1459 times
Wiring_Pigtails_Illustration_Guide.pdf
(3.96 MiB) Downloaded 1373 times
added circa 2020 pigtail connector pigtail info 8/3/22
2020 - WPT200 - Wiring Pigtails.pdf
(4.96 MiB) Downloaded 1552 times
Pigtail Final.pdf
(5.86 MiB) Downloaded 1439 times
Re: Motorcraft Wiring pigtail kits ID guide
Posted: 2022 Jan 14, 23:52
by rusty_lawrence
Which one is the male plug for two terminal act sensor for the early 90s mustang and lightning? Wpt-497 or 361 maybe?
Posted: 2022 Jan 16, 14:37
by mechanicalmatch
If you use search function (cntrl +f on windows), search air charge temp and at the back of the catalog there are a bunch of references. If you post up a picture of the sensor you are using or part number, I am sure we can narrow down further.
Posted: 2022 Jan 18, 11:16
by mechanicalmatch
added BWD illustration
rusty_lawrence, check PT309 on the BWD illustration.
Posted: 2022 Jan 18, 11:46
by rusty_lawrence
thank you! I think i found it. we'll see when it comes in.
Posted: 2022 Aug 03, 08:42
by mechanicalmatch
added motorcraft catalog from 2005 and 2020
