Motorcraft Wiring pigtail kits ID guide
mechanicalmatch
CVAF1
4R70 3.08
Motorcraft connector and pigtail catalog.
connectorcatalog.zip
(2.3 MiB) Downloaded 1276 times
added BWD connector illustration 1/18/22
bw11211-illustrated-connector-guide.zip
(3.04 MiB) Downloaded 1397 times
added circa 2005 motorcraft connector pigtail info 8/3/22
Wiring_Pigtails_Catalog (1).pdf
(755.69 KiB) Downloaded 1345 times
Wiring_Pigtails_Buyers_Guide.pdf
(2.98 MiB) Downloaded 1457 times
Wiring_Pigtails_Illustration_Guide.pdf
(3.96 MiB) Downloaded 1372 times
added circa 2020 pigtail connector pigtail info 8/3/22
2020 - WPT200 - Wiring Pigtails.pdf
(4.96 MiB) Downloaded 1550 times
Pigtail Final.pdf
(5.86 MiB) Downloaded 1435 times
rusty_lawrence
Vehicle Information: 1994 F150 Lightning
WAY1 / SMD-221 / AHAC2
Novi 2000 intercooled S/C
Re: Motorcraft Wiring pigtail kits ID guide
Unread post by rusty_lawrence »
Which one is the male plug for two terminal act sensor for the early 90s mustang and lightning? Wpt-497 or 361 maybe?
mechanicalmatch
CVAF1
4R70 3.08
If you use search function (cntrl +f on windows), search air charge temp and at the back of the catalog there are a bunch of references. If you post up a picture of the sensor you are using or part number, I am sure we can narrow down further.
mechanicalmatch
CVAF1
4R70 3.08
added BWD illustration
rusty_lawrence, check PT309 on the BWD illustration.
rusty_lawrence
thank you! I think i found it. we'll see when it comes in.
mechanicalmatch
CVAF1
4R70 3.08
added motorcraft catalog from 2005 and 2020
