Seemingly timed lean out periods
Not sure what could be causing this. I have always noticed a lean out period every 30 seconds or so. Is this normal or an issue with my tune? Black line is O2 Voltage.
Re: Seemingly timed lean out periods
post the log
SD40A_J1X_4.9L_05252021.zip
(431.06 KiB) Downloaded 648 times
Thanks, here are the current files I am running. Having trouble dialing in transient fuel and AE still
FYI this gasoline tune is rough as its not my daily tune. Just working on getting the gas tune dialed so I can switch fuels on the fly if E85 is not available.
