Posts: 419 Joined: 2021 Feb 16, 15:53
Vehicle Information: 1994 Flarside, XLT, 351w E4OD SD48b, Quarter Horse, Burn2
Unread post
by wwhite » 2021 Oct 08, 20:21
Is there an easy way to create xdf files after disassembly?
I have a bin file that is disassembled:
100% function,
90% tables
60% scalars
Is creating an XDF completely manual?
Posts: 7101 Joined: 2021 Feb 15, 12:23
Unread post
by decipha » 2021 Oct 08, 23:18
yep only way to do it
rzasa is my master xdf
I copy and paste the function and update the address. Makes life significantly easier.
There is a sad2xdf application floating around someone made but it doesnt use rzasa as a template so its been rather useless.
motorhead1991
Posts: 18 Joined: 2021 Feb 16, 01:22
Vehicle Information: 1990 Ford Ranger commercial: 2.3 turbo, FLH2 ECU, tuned with a Quarterhorse 1990 Ford Ranger Custom: 2.3 NA, e85 fed, Boport 1.5 NA grind cam, also tuned with a Quarterhorse.
Unread post
by motorhead1991 » 2021 Dec 09, 17:18
SAD806x has a utility to export to an XDF but you'll have to organize it all manually. I don't remember if it can also do the equations and stuff though
