And on the subject of EEC terminals...
MyShrink66
- Vehicle Information: 1966 Mustang HT, 5.0/4R70W, CBAZA
Is there a source for EEC-IV 60 pin female (can we still say that?) terminals. I had a pretty good stock before RJM disappeared but after a couple of custom harnesses my supply is about dry.
Trogdor
- Vehicle Information: 1993 Mustang 5.0 LX
- TFS 170 heads
- In fender MAC CAI
- 3" off-read X-pipe
- 3" 2 chamber mufflers
- 3" tailpipes
- 3.73:1 gears
- T3550
Re: And on the subject of EEC terminals...
I looked last year for some when I was doing my electric fan install and could not find any, all I found where ones that where either too big or too small. I actually bought them and physically tried them, but no dice. In the end I found someone that was selling an EEC-IV connector with the wires still attached and wound up using some of those for my fan and T4M0 conversion. But if anyone knows of a source I would not mind buying some just to have in my toolbox.
thats what I do I jack them from a junk harness
MyShrink66
Me too since I ran out of my supply of RJM's stuff. Thought I had found gold at Terminal Supply where I get a lot of my harness stuff but no Joy. On my swap from A9M to CBAZA I did a complete re-pin out. Unfortunately I ran into brittle terminal lock trouble and just about painted myself into a major corner. At that point I interposed Delphi connectors after the EEC connector and did my pin-out swap through them. Now I can change it back or whatever without worrying about broken terminal locks. Probably not a bad idea to grab any naked 60 pin connectors you might find...even at the stupid price. They won't be available for ever.
Trogdor
- TFS 170 heads
- In fender MAC CAI
- 3" tailpipes
- 3.73:1 gears
- T3550
I've got a couple of terminal locks that are broken. Other than super glue, and ingenious ways to fix them?
danielt
- Vehicle Information: 1990 Ford Mustang 5.0LX Convertible
5-speed, stock drivetrain
These are for the EEC-IV 60 pin plug.
Male terminals:
https://www.clipsandfasteners.com/Wedge ... a14887.htm
Female terminals:
https://www.clipsandfasteners.com/Wedge ... a14888.htm
The EEC-V plug is smaller diameter. The same company sells both.
Regards,
Daniel
Male terminals:
Female terminals:
Regards,
Daniel
motorhead1991
- Vehicle Information: 1990 Ford Ranger commercial:
1990 Ford Ranger Custom:
Those are the .110 pins, not the .060.danielt wrote: ↑2021 Mar 16, 23:14 These are for the EEC-IV 60 pin plug.
Male terminals:
Female terminals:
Regards,
Daniel
EEC-V uses an 0.040 size pin IIRC.
danielt
I believe EEC-V uses the 0.060 pins. I ordered those first and they were too small.
Trogdor
- TFS 170 heads
- In fender MAC CAI
- 3" tailpipes
- 3.73:1 gears
- T3550
For the EEC-IV the 0.060 pins are too small and the 0.110 pins are too big. We are in a Goldilocks situation here.
The manufacturer stopped making the ones you looking for. This information was posted on the old forums but it appears that information was lost with the conversion to this new forum. They have been discontinued for like 6 years now
