MAF curve shifting .001 after changing AHISL
Covers most all 98 fords including mustang v6, v8, cobra, lincoln town car, grand marquis and crown vic.
redtopracer
Unread post by redtopracer »
Like the title says, after doing the k constant thing and changing it to 30 and changing everything else back. Random points on my MAF curve move .001 lb/min and Im unable to change them back. Like 26.613 lbs/min needs to be 26.612 lbs/min but when you manually enter it, it refuses to save it even if i enter it and move the selected part of the curve.
I figure its a byte count issue? But its making me off by like 6% in areas.
Is there a work around?
Re: MAF curve shifting .001 after changing AHISL
Nope thats all the accuracy the ecu has.
6% sounds excessive. Can you give exact values.
redtopracer
Nawp, cause i cant math.
Disregard.
