AEM x-series Wideband
fordman428
Vehicle Information: 95 GT
363 Dart block flat top piston zero deck
AFR 195 heads 58cc chambers very close to 11:1 compression. Approximately .041 quench.
Cam specs 236/240 at .050 292/297 at .006 .600/.600 lift with 1.6 rockers
111.5 LSA Installed at 107.5 ICL
TFS R intake not box style, TFS Sn95 intake elbow, no EGR
75 mm BBK Sn95 throttle body
4 inch intake tubing with slot MAF from 06 E-series Van
no smog pump
1 5/8 shorty headers with wide bolt pattern flanges for now with Bassani 2.5 inch X-pipe. Bassani 2.5 inch cat-back and mufflers.
3.73 gears for now
T-5 with G-force 2.95 gear set and case.
wbo2_AEM-X
Unread post by fordman428 »
Installing the X- series AEM Wideband and I noticed some of the wiring is a little different than in the write up.I installed a new pin in terminal 27 for the 0-5v input on the ECM. The new gauge has a 0-5 volt ground wire that needs to be hooked up also. Reading the instructions it looks like they would prefer to have it hooked to the sensor ground or what I think Ford would call the signal return wire in my electrical diagram book. I assume the older AEM widebands are grounded internally to the gauge ground so this was not needed and seemed to work just fine. There is a nice ground point right next to the EEC IV that would be easy to use. Has anyone used one of these new widebands and encountered this?
https://www.aemelectronics.com/files/in ... 0-0300.pdf
Re: AEM x-series Wideband
all of them are supposed to be grounded at the ecu but its not that critical
