ways to minimize decel POP?
canuck1
Unread post by canuck1 »
Is there a parameter (A9L2) that can help reduce the amount of popping that comes out of my sidepipes on deceleration? Anytime I get off the throttle there is some loud exhaust cackling that sounds kind of like a squadron of Harley-Davidson's. I'm hoping to make better friends of my neighbors down the hill from my house!
Sean
Re: ways to minimize decel POP?
check fn111 the closed throttle spark and kick it up at the higher rpms
then the dashpot spark multiplier set anything lower than 1 to 1
canuck1
Thanks.
I altered some values in FN389-Dasphot CT Spark Multiplier and added a 2 degrees to each of the top 2 FN111 Y axis values.
- Is that enough additional timing to start?
- What's the indicator if the FN111 values are too high?
Sean
