I added the trickflow 01d104b 24lb injector data to the homepage for those using them. Only at 39.15 psi so if you run them at other pressures you'll have to dial them in.
Interestingly enough they have the same offset as the 30lb tfx injectors so I would venture a guess the only difference between the silver tfx injectors is the opening and they use the same coils.
http://www.efidynotuning.com/injdata.htm
Injector Data Added - TFS #01D104B 24 lb/hr @ 39.15psi
