To PMW or not to PWM for fuel?
Ive been going back and forth regarding using computer controlled PWM fuel or not. The ultimate plan is to have a boosted 302 in the truck. I will most likely end up using dual pumps since I will be running e85. Should I just skip the factory PWW? Thinking of using a vaporworx dual pump pwm controller instead since it will control dual pumps. I might just do a smaller pump for the main pump and trigger a 340lph using a Hobbs switch like im doing in my mustang. It works good. Thoughts?
Re: To PMW or not to PWM for fuel?
up to you makes no difference
What is necessary to run a second pump with factory control?
second fpdm
