ECU that supports both a distributor and PWM fuel control
Is there an ecu out there that can operate the TFI distributor ignition system in the 94/95 mustang and has PWM fuel control? pretty sure the answer is no but I thought I would check.
Re: ECU that supports both a distributor and PWM fuel control
correct
that would be a negative ghost rider
you can always run two ecus though
