BE 5.931 Wideband O2 config issues
Posted: 2026 Apr 01, 21:50
by JMG9350
Binary Editor performed an update to Ver. 5.931, my tune files have disappeared, and now the way the wideband is configured in BE has changed, and no longer works. I have read the help/user's manual, and I have entered the information how I think I understand it, and it still will not convert the EVP 0-5V signal to AFR.
This all worked before the update. Does anyone know how to configure this, and can explain what I'm doing wrong?
Re: BE 5.931 Wideband O2 config issues
Posted: 2026 Apr 01, 22:00
that looks correct
make sure you have evp selected to log in the payloads
Posted: 2026 Apr 01, 22:19
by JMG9350
It is set up to log in the payloads, and it just shows a range of 0-5V. It is receiving information from the wideband, but it is not converting it to AFR. I emailed Clint Garrity, and have not heard anything in 4 days.
Posted: 2026 Apr 01, 22:30
by JMG9350
This example of the unchanged EVP volts to AFR, there are no parentheses in the expression formula. Should I try that?
Posted: 2026 Apr 02, 19:12
yeah try it out
Posted: 2026 Apr 04, 17:48
by JMG9350
Removing the parentheses does not correct it either. I'm at a loss. Clint still has not responded to my email either
Posted: 2026 Apr 05, 06:52
by jsa
Turn off auto updates and go back to an earlier version is likely the solution for now.
