BE 5.931 Wideband O2 config issues
JMG9350
Vehicle Information: 1993 Mustang GT, A9L, Moates QH/BE
306cid, stock crank and rods, Trick Flow flat top pistons, Speed Pro plasma moly rings, TFS TW170 ported 1st gen heads, Jones Cam Design custom camshaft and hyd roller lifters, JBA headers, BBK X pipe with cats, Borla cat back exhaust, Explorer intake ported by TMoss, Accufab 70mm TB and spacer, Holley 36lb injectors, 70mm SN95 MAF, TKX transmission, aluminum driveshaft, 3.55 gears
Post by JMG9350 »
Binary Editor performed an update to Ver. 5.931, my tune files have disappeared, and now the way the wideband is configured in BE has changed, and no longer works. I have read the help/user's manual, and I have entered the information how I think I understand it, and it still will not convert the EVP 0-5V signal to AFR.
This all worked before the update. Does anyone know how to configure this, and can explain what I'm doing wrong?
Re: BE 5.931 Wideband O2 config issues
Post by decipha »
that looks correct
make sure you have evp selected to log in the payloads
JMG9350
Post by JMG9350 »
It is set up to log in the payloads, and it just shows a range of 0-5V. It is receiving information from the wideband, but it is not converting it to AFR. I emailed Clint Garrity, and have not heard anything in 4 days.
JMG9350
Post by JMG9350 »
This example of the unchanged EVP volts to AFR, there are no parentheses in the expression formula. Should I try that?
Post by decipha »
yeah try it out
JMG9350
Post by JMG9350 »
Removing the parentheses does not correct it either. I'm at a loss. Clint still has not responded to my email either
Post by jsa »
Turn off auto updates and go back to an earlier version is likely the solution for now.
