locked timing and DESMAF_PID_N
Posted: 2025 Oct 24, 00:22
by danielt
Once into a warm stable idle, timing seems locked at 20 deg and only ISC is responding to control idle. Also, no matter how I adjust ITHBMA, DESMAF_PID_N is always 0. I should be using the default patches in A9L2, so should be using the expanded spark FN841XX to adjust timing with RPM delta. Any guidance or direction appreciated.
Re: locked timing and DESMAF_PID_N
Posted: 2025 Oct 25, 09:47
is the closed throttle flag being set?
Posted: 2025 Oct 25, 14:19
by danielt
Yes, it is -1. i set TRLOAD to 0 and now it works. Still trying to figure out if I should set to 0 or 1
Posted: 2025 Oct 26, 17:57
by danielt
I'm trying to figure out why crank spark is at 0. SPK_UNDSP is set at 10.
