locked timing and DESMAF_PID_N
danielt
- Vehicle Information: 1990 Ford Mustang 5.0LX Convertible
5-speed, stock drivetrain
Once into a warm stable idle, timing seems locked at 20 deg and only ISC is responding to control idle. Also, no matter how I adjust ITHBMA, DESMAF_PID_N is always 0. I should be using the default patches in A9L2, so should be using the expanded spark FN841XX to adjust timing with RPM delta. Any guidance or direction appreciated.
- A9L2_20251019_3.bin
- (56 KiB) Downloaded 958 times
- short drive.xdl
- (662.3 KiB) Downloaded 1089 times
Re: locked timing and DESMAF_PID_N
is the closed throttle flag being set?
danielt
Yes, it is -1. i set TRLOAD to 0 and now it works. Still trying to figure out if I should set to 0 or 1
danielt
I'm trying to figure out why crank spark is at 0. SPK_UNDSP is set at 10.
- 20251025 warm start.xdl
- (386.62 KiB) Downloaded 1039 times
- A9L2_20251024.bin
- (56 KiB) Downloaded 1002 times
