Bin for 99 F-150 5.4l Mlc-481a
ECU is good but tune is corrupt does anyone out there have a bin? Catch code is HNE3.
Re: Bin for 99 F-150 5.4l Mlc-481a
Is HNE3, MBAIB strategy?
Are you using the right xdf to avoid corrupting?
034v
256k Attached
- HNE3.bin
- (256 KiB) Downloaded 775 times
awesome thanks! i presume I will need to disable PATS somehow
034v
Theft light is solid now and there is a no start condition. Since the ecu rom is no good masking is not going to work. Is there any good info on disabling pats in the bin provided? Also I assume the vin should be programmed as well
034v
What module are you using to tune it?
Binary is setup for TI chip, F3V2 or SCT 6600.
HEX, Vin and copyright are all in the same location on all 4 bank binaries. If you need me to convert to 224k or 216k I can, but I need to know bank order you want. 0189, 0891 ect..
F3v3. I wrote the bin as is and it appears to work. Just need to disable pats and write vin.
034v
Those addresses are all (0xFF) in the bin as you said. What should be written for PATS to disable?
