Bin for 99 F-150 5.4l Mlc-481a
Covers v8 mustangs in 99-early 01 years. Can be configured for V6 easily and cobras as well as trucks and other fords if hardware is compatible.
ECU is good but tune is corrupt does anyone out there have a bin? Catch code is HNE3.
Re: Bin for 99 F-150 5.4l Mlc-481a
Is HNE3, MBAIB strategy?
Are you using the right xdf to avoid corrupting?
034v
Unread post by 034v »
256k Attached
HNE3.bin
(256 KiB) Downloaded 779 times
awesome thanks! i presume I will need to disable PATS somehow
034v
efloth wrote: ↑2025 Oct 20, 13:02 awesome thanks! i presume I will need to disable PATS somehow
Not sure if you will need to as all of the PATS, HEX area and vin are blank. Might tho. I'm used to tuning 4 banks with it masked or ignored by a SCIL module.
Theft light is solid now and there is a no start condition. Since the ecu rom is no good masking is not going to work. Is there any good info on disabling pats in the bin provided? Also I assume the vin should be programmed as well
034v
efloth wrote: ↑2025 Oct 20, 18:48 Theft light is solid now and there is a no start condition. Since the ecu rom is no good masking is not going to work. Is there any good info on disabling pats in the bin provided? Also I assume the vin should be programmed as well
What module are you using to tune it?
Binary is setup for TI chip, F3V2 or SCT 6600.
HEX, Vin and copyright are all in the same location on all 4 bank binaries. If you need me to convert to 224k or 216k I can, but I need to know bank order you want. 0189, 0891 ect..
F3v3. I wrote the bin as is and it appears to work. Just need to disable pats and write vin.
034v
efloth wrote: ↑2025 Oct 21, 10:05 F3v3. I wrote the bin as is and it appears to work. Just need to disable pats and write vin.
VIn should be 0x3FF80
PATS should be 0x3FF13
Copyright should be 0x3FF63
If not, lmk what you find.
Those addresses are all (0xFF) in the bin as you said. What should be written for PATS to disable?
