Going from OL to CL EEC-V
Posted: 2025 Jan 31, 23:01
I'm not sure if I should post this here or under the CRAI8 section. Please move it if I have made a mistake.
I've had a small issue with the CHT that I fixed up and installed. It was not getting warm enough, under reporting. It wasn't designed to go where
I put it. I have now disconnected it which was piggybacked off of the existing ECT circuit. I plugged the ECT back in and I'm getting better temperature readings but still in OL. After watching the ECT in real time, I suspect that a PO put a 180F thermostat in it and it should have a 192F.
I have a question about the front HEGO warm temp. In the bin file, it is set at 2000F. Shouldn't it be more like 500F ?
