2000 ford mustang gt pats disable need help
Covers v8 mustangs in 99-early 01 years. Can be configured for V6 easily and cobras as well as trucks and other fords if hardware is compatible.
Nesqu1k2010
Vehicle Information: 2000 mustang gt
Unread post by Nesqu1k2010 »
can anyone help to disable pats , i used pcmflash module 29 to read it , i even ca pay for it if needed , thx
XU7AABA_CVAF1B3-20241220-125509.bin
(224 KiB) Downloaded 818 times
Re: 2000 ford mustang gt pats disable need help
download the file converter in the programming section and convert to 256
open with tunerpro and cvaf1 xdf
disable pats, save the file
convert it back to 224 and write it back
/enjoy
This thread is from last December. I did as you instructed the original thread starter and then was curious of what changes occurred. There were 4 changes. I assume that the changes have to do with everything from checksum to switching power onto injectors and maybe even something to do with the security indicator light? Just curious.
simply open it with tunerpro and do a compare
you have everything you need already
