VEX1 BE / AHAC2 XDF issue
Used on mid 90s mass-air broncos and F-Series trucks. SMD-221 Hardware.
Cal Codes: HOG0, HOG1, TIP1, VEX1, WAY1
95GTSpeedDemon
Vehicle Information: 95 mustang
Unread post by 95GTSpeedDemon »
so i loaded BE with the free VEX1, made the necessary changes, and i cant seem to make it force OL and changing the maf curve 30% didnt seem to change the AFR. its logging, so idk whats going on.
loaded AHAC2 xdf and the same bin file. the maf curve was WAY different. checked sct and it is very close to BE's numbers that i put in.
ideas?
im a cbaza/gufb long time user, but its been a while since i had to tune one so im a little rusty; and never got the hang of TP anyway.
Re: VEX1 BE / AHAC2 XDF issue
you need to change the scaling percentage to 1 in tunerpro if you want to compare it directly to other software
