TP or QH issue?
blacksaleen95
Vehicle Information: 93 Mustang GT
TP or QH issue?
Unread post by blacksaleen95 »
So I"m new to the QH, but been messing with stand alones for years.... looking for some guidance as I'm not having any luck with my current setup just getting up and running.
Problem: FP continues to run KOEO, no datalogging/live values with TP RT.
From my reading it appears that's a common issue with a dirty J3 port. So I verified there was no grease/silicone left on the pads.
What I've tried with no luck:
Cleaning J3 pads on ecu multiple times, lightly scuffed with sandpaper, cleaned with electronics cleaner.
Loaded A9L2 BIN, GUFX 240206 XDF, DECIPHA_230417 ADX, *successful" upload and verify
Loaded Factory A3M BIN, GUFB XDF, DECIPHA 230417 ADX "successful" upload and verify
Changed Coin battery on QH
I am able to upload the BIN to the QH and verify it (with both BIN files) I'm assuming I will only get live QH data with the patched decipha file? I have setup TP as instructed on the "Getting Started" page
The car will start but sounds like it's loading up.
If I remove the QH it runs as it should with no issues.
QH firmware is 1.6, TP RT is 5.00.10018.00
I've scoured the forums and tried to be self sufficient here, but I'm going in circles so hopefully someone has some insight.
Any help is much appreciated.
Thanks,
Jim
Re: TP or QH issue?
it specifically states do not start the car if the fuel pump runs non stop.
No such thing as a dirty j3 port. It probably still has the plastic layer on it. You need to scrape it off with a razor blade.
You can enable datalogging on any file you wish before you write it.
It specifically states to poll data and verify communication before starting. If you cant get any data then dont start it.
