98 ECU in 96 Vehicle
pmazza
Vehicle Information: 1990 Mustang LX
A9L
Vortech 3SI
Fordstrokers 331
wbo2_aem-x
1972 Corvette
A9L
468 big block
wbo2_92_AEM-UEGO
Unread post by pmazza »
We have a 96 Cobra with the 2 bank ecu that has minimal OBD2 flash support and datalogging is erratic at best even with QH. Stock bottom end and B heads. This car is not going to have crazy mods and will remain mostly as Ford built it. EGR/Secondary air injection is gone, IMRC is on and bench tested ok.
The only option I have found that appears to reliably support the 2 bank ecu is SCT PRP and X2/3/4.
With all that in mind, we were considering tracking down an 8 cyl 4.6 ECU from 1998 as they are 4 bank and still have the same ignition setup as the 96 car. We would start with a 98 Cobra bin. Support for flash and logging looks to be much better for this type of ECU.
We did not think a 99-04 ecu would work since COP was implemented.
Any thoughts on feasibility of that plan are appreciated.
Thanks.
Phil
Re: 98 ECU in 96 Vehicle
can you use the 03/04 ecu no prob just won't have tach unless you swap to the newer cluster
cop doesn't matter just simply set if for coil pack
98 ecu is fine too and tach should work
