Page 1 of 2
[Wanted] 351W E4OD stock tune
Posted: 2024 Jul 03, 01:07
by yaboyhalle
Currently trying to return a new to me truck to stockability again. It was running on an SD2x EEC, with what i assume is a 5.0 manual tune, spout out, timing locked to ~30. Not the best home mechanic.
Best replacement i could find was a SD47B EEC with a 5.0 E4OD stock tune. I'd rather start with the right calibration on this correct hardware.
Re: [Wanted] 351W E4OD stock tune
Posted: 2024 Jul 03, 08:50
by rusty_lawrence
this is one from my lightning
Posted: 2024 Jul 03, 12:16
by wwhite
Here is a 1994 351w E4OD non-lightning SD48B.
I had ran the stock C3P2 on a stock non-lightning 351w and would pop/backfire through intake in certain conditions.
KID2.bin
(56 KiB) Downloaded 1377 times
I believe LAD1 is the newest code (1996) for 351w E4OD.
LAD1.bin
(56 KiB) Downloaded 1413 times
Posted: 2025 Jan 02, 19:17
by yaboyhalle
Thanks for the help. I was able to modify a Z2D tune with data from the LAD1 and it worked perfectly. Truck is up and moving!
Posted: 2025 Aug 12, 22:38
by yaboyhalle
Came into another sd48B, with stock bin LE01. Is it just me, or are the 351w tunes (LAD1, KID2, and this LE01) not reading on the A1C.xdf?
Posted: 2025 Aug 12, 22:40
they arent going to its a different strategy
you have to use the a1c files provided in that thread
Posted: 2025 Aug 13, 00:05
by wwhite
yaboyhalle wrote: 2025 Aug 12, 22:38 Came into another sd48B, with stock bin LE01. Is it just me, or are the 351w tunes (LAD1, KID2, and this LE01) not reading on the A1C.xdf?
Thats L - lima E - echo O - oscar - 1 (LEO1), not LE zero one(LE01).
That is 100% identical to KID2, exactly.
Very different than A1C.
Posted: 2025 Aug 29, 20:19
by yaboyhalle
It seems a bit too thin to be an Oh, but I wouldn't know what font they're using. Either way, I was just looking to find an A1C bin for a 351, as adapting a 302 tune isn't as easy.
Posted: 2025 Sep 02, 12:21
by wwhite
The O do not have a line through them like the zeros.
Googling these codes, makes a difference.
I tend to be a bit pedantic with this stuff.
Posted: 2025 Sep 02, 12:24
by wwhite
yaboyhalle wrote: 2025 Aug 29, 20:19 It seems a bit too thin to be an Oh, but I wouldn't know what font they're using. Either way, I was just looking to find an A1C bin for a 351, as adapting a 302 tune isn't as easy.
The A1C.bin is located in the first post of this group.
You must use the matching XDF.
