Stock Maf meter Peg
Posted: 2024 Jun 23, 18:56
by waltnono
Just bought a Allen supercharger and I have 39lb injectors and stock 02 GT Maf. Only looking to make 350rwhp with this build. Will stock 80mm Maf support this? Also what's the upper hp limit to stock 80mm Maf sensor.
Re: Stock Maf meter Peg
Posted: 2024 Jun 24, 09:55
an 80mm pipe will support more than what the maf element will measure. Not a problem though if you fail the maf and use failed load. If you want to actually dial it in and get it situated with the maf reading then you'll need to upgrade to a pmas hpx-e slot maf.
Posted: 2024 Jun 24, 20:44
by waltnono
Thanks. I'll go that pmas route.
