Stock Maf meter Peg
waltnono
Vehicle Information: 1995 Mustang V8 Swap
WH40
76mm Turbo
4r70W
wbo2-uego
Stock Maf meter Peg
Unread post by waltnono »
Just bought a Allen supercharger and I have 39lb injectors and stock 02 GT Maf. Only looking to make 350rwhp with this build. Will stock 80mm Maf support this? Also what's the upper hp limit to stock 80mm Maf sensor.
Re: Stock Maf meter Peg
an 80mm pipe will support more than what the maf element will measure. Not a problem though if you fail the maf and use failed load. If you want to actually dial it in and get it situated with the maf reading then you'll need to upgrade to a pmas hpx-e slot maf.
waltnono
WH40
76mm Turbo
4r70W
wbo2-uego
Thanks. I'll go that pmas route.
