Page 5 of 8
Re: SUB2 stock bin - '95 4.9L E4OD
Posted: 2023 Jun 09, 00:05
by wwhite
I'll attempt to test on truck this weekend.
Will give me the opportunity to use TI J3 chip.
Posted: 2023 Jun 09, 02:16
by wwhite
Updated the data logging patch to insert 0xff ... upon removal.
TunerPro button for Remove Patch was not enabled, the attached fixes this.
Posted: 2023 Jun 09, 02:26
by wwhite
For SD V8 351 users, here is my modified bin.
This is a screen shot of changes going from 300ci 6cyl, to 351ci 8cyl:
SUB2 v6 to v8 changes
Posted: 2023 Jun 09, 13:50
by Sevensecondsuv
Thanks all. What is everyone using for an adx file?
Posted: 2023 Jun 09, 15:54
by efloth
We will need to take Michael's standard ADX and add the payload info for SUB2.
Posted: 2023 Jun 09, 17:53
by wwhite
efloth wrote: 2023 Jun 09, 15:54 We will need to take Michael's standard ADX and add the payload info for SUB2.
I didn't even think about that when I included the data logging patch.
Here is the current OPs list, probably quite wrong right now in the XDF:
D6009603B6009A00CC00BA00B40024018A006201F201BE00960070011A01540192008C009000B800B200A8005C016A01DA001A0228024E013802D8005C03140322036C01980300002700015D9E000444A500804400000000
Posted: 2023 Jun 12, 15:03
by efloth
This is the A1C payload info. Did you assume it would be the same on SUB2?
Either way we will need to fill the SUB2 columns of this out.
A1C-J1X-SUB2 Payload.xlsx
(17.64 KiB) Downloaded 1775 times
Posted: 2023 Jun 12, 16:03
by wwhite
Didn’t assume, just didn’t think about it.
It’s going to be different.
I can populate that later tonight with correct info
Posted: 2023 Jun 12, 23:57
by wwhite
Here is the sheet with columns filled for SUB2.
A couple are blank, for various reasons, like TOTLDST and VMAF do not exist in LHBH1 strategy.
Also, not sure how the byte payloads are loaded( does QH/TP load a word, and mask the byte).
I put the actual byte address in for payload.
https://docs.google.com/spreadsheets/d/ ... ue&sd=true
Posted: 2023 Jun 13, 12:46
by efloth
give'r a shot
Decipha_210620_SUB2.adx
(384.68 KiB) Downloaded 1759 times
