Electric fan control on Sd4x
Re: Electric fan control on Sd4x
Yes, I was interpreting that all wrong. The link below helped me understand the fundamentals of the output but both examples use an external transistor. is that what you mean by TTL Logic in your diagram?
https://www.microcontrollertips.com/wha ... drain-faq/
Finally figured it out! I'm using a pull-up resistor connected to the 5 volt reference pin. That is then connected to the ECU pin and the high input of the relay board. Once I implement the optocoupler circuit, I will send pictures and schematics.
Got the optocoupler circuit figured out. I was able to use a bunch of available pads/traces and solder it right in. Not my prettiest work but should get the job done safely. IC is Cosmo 1010. More to come.
Float (Relay On)
91 01 46 B0 Pin 24
91 02 46 B1 Pin 23
91 04 46 B2 Pin 22
91 08 46 B3 Pin 21
91 10 46 B4 Pin 20
91 20 46 B5 Pin 19
91 40 46 B6 Pin 18
91 80 46 B7 Pin 17
Drain (Relay Off)
71 fe 46 B0 Pin 24
71 fd 46 B1 Pin 23
71 fb 46 B2 Pin 22
71 f7 46 B3 Pin 21
71 ef 46 B4 Pin 20
71 df 46 B5 Pin 19
71 bf 46 B6 Pin 18
71 7f 46 B7 Pin 17
That’s awesome. That spare pad area you used is where the knock sensor chip would be on 6cyl sd47 hardware, fyi
Should be able to start putting the truck back together next week. Thinking about writing the code in a super simple way. It will just be:
If fan is on and ect is below 205f (thermostat temp) turn fan off.
If fan is off and ect is above 211f turn fan on.
The relay board has selectable hi/low inputs so I have already tested wiring it to the ac clutch 12v wire with good success. I will use two relays for each input for redundancy.
Any issues with the code idea?
This code worked out beautifully. I hard coded on/off setpoint values because I did not know how to reference an address this late in the code. I am not sure how to add a new reference address that would allow it.
Sub_c600:
c600: ef,59,f9 call bf5c Sub_bf5c (); 'call datalogging routine
c603: 33,46,09 jnb B3,R46,c60f if (B3_R46 = 1) { ' check if fan is on. If not skip to c60f
c606: 99,60,b6 cmpb Rb6,60 ' compare ect with 60
c609: d6,03 jge c60e if (Rb6 < 60) { 'if < 60 'if > 60 skip to c60e, turn fan off if not
c60b: 71,f7,46 an2b R46,f7 B3_R46 = 0; }
c60e: f0 ret return; }
c60f: 99,69,b6 cmpb Rb6,69 'compare ect with 69
c612: de,03 jlt c617 if (Rb6 >= 69) { ' if ECT >= 69 turn fan on. skip to c617 if not
c614: 91,08,46 orb R46,8 B3_R46 = 1; }
c617: f0 ret return;
This worked out great. Use the cooling fan scalars I added to adjust on/off setpoints. Make sure the on setpoint is greater than the off setpoint or you may end up with very undesirable results.
- A1C_230830 with fan patch.xdf
- (297.87 KiB) Downloaded 936 times
very nice
so long as it works thats all that matters.
For reference not that it matters but here's the fan code I wrote for RZASA a few years back.
its in the rzasa xdf you can enable it and disassemble it if you want the actual listing
1xab42 vector list calls 8xff28
8xff28 calls 1dcd7
1dc31 - begins vsf code
1df95 - end of vsf code
0x365 == 869 bytes of code
1xdcd7 code injected
<----deciphas fan code---->
3/19/2019 0200
:fan_disable
if vsbar > 58 , fans_off
if atmr1 > 3 , hsf
if engofftmr < 13 skip
if vbat < 11.5 , fans_off
if engofftmr < 3 , fans_off
if engofftmr > 254 , fans_off
:hsf
if !hedfhp goto lsf
if ect >= hsf_on goto hsf_rqst
if !hsf_rqst skip
if ect > hsf_off goto hsf_rqst // a/c would continue
:lsf
if !edfhp fan__ac
if ect >= lsf_on goto lsf_rqst
if !lsf_rqst skip
if ect > lsf_off goto lsf_rqst // a/c wouldn't apply anyways
:fan__ac
if !ac_rqst goto fans_off // turns off lsf normally
if !hedfhp goto lsf_rqst
:hsf_rqst
edf_ppm == xxx // give air for idle hsf
if !lsf_rqst skip 2
pcm_pin_lsf == off // turn off lsf before turning on hsf
lsf_rqst == 0
hsf_rqst == 1
pcm_pin_hsf == on // coded inverted hsf and pin location
goto exit
:lsf_rqst
if !edfhp exit
edf_ppm == xxx // give air for idle lsf
if !hedfhp skip
pcm_pin_hsf == off // turn off hsf before turning on lsf
hsf_rqst == 0
lsf_rqst == 1
pcm_pin_lsf == on // coded inverted lsf and pin location
goto exit
:fans_off
edf_ppm!
if !lsf_rqst skip 2
lsf_rqst!
if !hsf_rqst skip 2
hsf_rqst!
:exit
f0 return
b1 74 34
9b e2 4f 34
d9 xx
b1 03 34
98 34 7c
db xx
b3 d6 ff 34
99 0d 34
d1 xx
b1 b8 34
9b 01 63 07 34
d1 xx
b3 d6 ff 34
99 03 34
d1 xx
b3 d6 ff 34
99 fe 34
d1 xx
99 00 00
df xx
99 69 79
d6 xx
b3 d2 f7 3c // load fan flags 377 bit4=hsf bit5=lsf
34 3c xx
99 68 79
d2 xx
99 00 00
df xx
99 65 79
d6 xx
35 3c xx
99 63 79
d2 xx
b3 e2 ce 34
35 34 xx
99 00 00
df xx
a1 00 04 34
c3 e8 c6 34
35 3c xx
71 ef 6a // pcm pin 19 lsf off
71 20 3c
91 10 3c
91 01 6d // pcm pin 46 hsf on
20 xx
99 00 00
df xx
a1 00 02 34
c3 e8 c6 34
99 00 00
df xx
71 fe 6d // pcm pin 46 hsf off
71 ef 3c
91 20 3c
91 10 6a // pcm pin 19 lsf on
20 xx
01 34
c3 e8 c6 34
35 3c xx
71 20 3c
34 3c xx
71 ef 3c
c7 d2 f7 3c
f0
