Crank trigger angle
OldBroncoRacer
Vehicle Information: 1996 F150 4X4 PreRunner 418W 270 Cam EWPI Heads SpeedMaster 5.8L Mustang 75mm Intake FTPF-AWA ZJT0 AGANNE9 ML1-441 4.86's 35X12:50-15's
2001 Ranger Desert Racer 408W XE282-HR Cam Full Manual 4R70W AFR's Pro-M Intake etc Crown Vic PCM
Re: Crank trigger angle
Unread post by OldBroncoRacer »
dleach1407 wrote: 2023 May 04, 18:02 I don't know how well that will work out for you. I have that same pickup or at least one that looks the same. Is your magnetic? If not I don't think it will work. The one I have depends on magnets in the trigger wheel and it's designed to trigger an msd ignition box like a 6al
It's a 2 wire VR sensor for the crank, and also for the cam position sensor. I got the wheel and the CPS (with VR) from 64-Bit.
For the wheel, I machined an 1/8th off the front of the snout, right behind lower pulley. The indicator's from Innovators West.
The first sensor I got, was an Innovators West, or Speedmaster, was a 2 wire VR but didn't seem to be magnetic, like the Ad said. Sent it back to Summit.
The current one is an MSD 8505 Magnetic, but only to a certain degree. Nowhere as strong as a VSS sensor, or the stock 1996 351W Misfire dealio for that matter, but don't know if it needs to be.
I've seen others, but so far haven't pursued.
I need to find out the specs on what the PCM is expecting for amplitude, as it varies with speed. Since the 408 completion is still aways away, I'm going to fab up an adapter to spin the wheel to see what the sensor output is with an O'Scope.
Anyone have an idea on specs?
-ed
dleach1407 wrote: 2023 May 07, 00:46 Can I also get some clarification on the cam sensor? It appears the ecu pinout has a cam+ but no cam-. Do I just use the signal return for the cam sensor? Looking at the stock harness I believe that's how it's wired but I want to make sure that's the proper way to wire it.
Bump.. Still need verification on this
Unread post by RinerAuto »
dleach1407 wrote: 2023 May 11, 22:00
Yes use signal return for cam position
Cam position sensor:
Pin 1 -> Signal Return EECV pin 91
Pin 2 -> CAM EECV pin 85
