Global K Constant / Scaling Percentage
Re: Global K Constant / Scaling Percentage
CORRECTION percentage not actual value.
You can have a 500% correction simply multiply the value by 5. For example if you have .19 load at 200 ad counts and 3k rpm and the histogram tells you there is a 5.00% error. Then simply multiply that cell by 5 and you will get a new value of (.19 x 5 == 0.95). Then next time you roll around in that cell you'll have a near 0 error.
DOHCTOR_32V
Vehicle Information: 95 Cobra
Unread post by DOHCTOR_32V »
LOL, I was out mowing grass this evening and this dawned on me - PERCENTAGE! DOH! I appreciate your help and reassurance. Sorry, I didn't catch it the first time around.
So, it has to be manually corrected in each cell - as in there is no short cut way to apply the corrections to all cells at once?
DOHCTOR_32V
decipha wrote: ↑2022 Jun 30, 19:05
open up the histogram you want and set it to average
History Average or Running Average? How do those two differ?
running average
no idea how history average is populated but it doesnt give correct values
