CORRECTION percentage not actual value.
You can have a 500% correction simply multiply the value by 5. For example if you have .19 load at 200 ad counts and 3k rpm and the histogram tells you there is a 5.00% error. Then simply multiply that cell by 5 and you will get a new value of (.19 x 5 == 0.95). Then next time you roll around in that cell you'll have a near 0 error.
Global K Constant / Scaling Percentage
DOHCTOR_32V
Re: Global K Constant / Scaling Percentage
LOL, I was out mowing grass this evening and this dawned on me - PERCENTAGE! DOH! I appreciate your help and reassurance. Sorry, I didn't catch it the first time around.
So, it has to be manually corrected in each cell - as in there is no short cut way to apply the corrections to all cells at once?
DOHCTOR_32V
running average
no idea how history average is populated but it doesnt give correct values
