And on the subject of EEC terminals...
motorhead1991
- Vehicle Information: 1990 Ford Ranger commercial:
1990 Ford Ranger Custom:
Re: And on the subject of EEC terminals...
EEC-IV uses a 0.080/2mm pin, I haven't found a suitable replacement yet. We (OpenEEC) did make an interesting discovery for EEC-V though
Trogdor
- Vehicle Information: 1993 Mustang 5.0 LX
- TFS 170 heads
- In fender MAC CAI
- 3" off-read X-pipe
- 3" 2 chamber mufflers
- 3" tailpipes
- 3.73:1 gears
- T3550
If anyone is interested I managed to find a company that has these pins in stock, both the 14ga. and 18ga. Only caveat is that the minimum quantity is 200 pins. I went ahead and bought 200 of each wire size and tried them on an EEC-IV and I can confirm that they fit! I really only wanted 10 of each to keep as spares, so anyone else want to buy 190 pins of each size?
probably help to list your price
Trogdor
- TFS 170 heads
- In fender MAC CAI
- 3" tailpipes
- 3.73:1 gears
- T3550
Just to update, I've sold all of the remaining connector pins I had, but here is the information where I purchased them:
Nexus Electronics
E7EB-14488-GA (18ga.)
E7EB-14488-NA (14ga.)
The lowest quantity they sell is 200ea.
Nexus Electronics
The Nexus parts are for 60 pin EEC.
C and F do not have the right size for 60 pin EEC.
Thanks for the remaining pins you had.
AcesArneson
- Vehicle Information: 1973 Mustang Convertible
Trogdor wrote: ↑2021 Oct 12, 14:30 If anyone is interested I managed to find a company that has these pins in stock, both the 14ga. and 18ga. Only caveat is that the minimum quantity is 200 pins. I went ahead and bought 200 of each wire size and tried them on an EEC-IV and I can confirm that they fit! I really only wanted 10 of each to keep as spares, so anyone else want to buy 190 pins of each size?
Do you still have these pins for EEC-V?
Trogdor
- TFS 170 heads
- In fender MAC CAI
- 3" tailpipes
- 3.73:1 gears
- T3550
I never had any for an EEC-V and I sold all the ones I had for an EEC-IV.AcesArneson wrote: ↑2024 Feb 24, 21:52Trogdor wrote: ↑2021 Oct 12, 14:30 If anyone is interested I managed to find a company that has these pins in stock, both the 14ga. and 18ga. Only caveat is that the minimum quantity is 200 pins. I went ahead and bought 200 of each wire size and tried them on an EEC-IV and I can confirm that they fit! I really only wanted 10 of each to keep as spares, so anyone else want to buy 190 pins of each size?
