yep
when you reinstall the frps set the frps one back to 2 to enable deltap and set inj_pw_comp so if pressure drops and the injectors can still keep up you wont lean out and blow the engine
FBFG2/PTP2 > FBGI0
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Re: FBFG2/PTP2 > FBGI0
Gotcha, perfect.
I take it all is normal / same now ?
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Seems to be. Starts normal, Reverse and Drive engagement seems normal when cold, but haven't driven it yet.
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Random question... Did you do any 'massaging' beyond just porting the PTP2 values from FBFG2 to FBGI0? The only reason I ask is the reverse and drive engangements seem better on the FBGI0 strategy file than they were with the bone stock PTP2/FBFG2. Maybe it's just a placebo effect or my imagination lol.
fbgi0 doesnt have a native automatic cal
all of the background values I populated with what i saw fit
so there will be some variance in tiny nuances between them
