EPA / Tuning
entity-unknown
EPA / Tuning
So the tuning world just had a massive hit thanks to the EPA. How does it feel?
Re: EPA / Tuning
can you be more specific? maybe throw a link?
entity-unknown
Re: EPA / Tuning
Re: EPA / Tuning
Thats nothing new.
entity-unknown
Re: EPA / Tuning
As I understand it the EPA has shutdown several tuners like COBB. Moates has no tuning hardware to sell for Ford anymore either.
Are you saying this is incorrect? Honest ?
Neald
Vehicle Information: 1989 Ford Bronco II
Stock 2.9 V6, A4ld trans.
CBAZA(6CYL Config)
Moates quarterhorse
Re: EPA / Tuning
Unread post by Neald »
Practically impossible to find any Quarterhorse, F3 and jaybird right now. I know this is for obd 2, but how about switching to a newer ECM and repining a bit and tuning with this..
https://www.drewtech.com/mongoose/ford.html
entity-unknown
Re: EPA / Tuning
Fortunately I got my QH and an extra F3v2 chip a few months before they listed everything out of stock :)
