ZYA2 K-Constant
ZYA2 K-Constant
Unread post by bad86capri »
I noticed that the K-Constant in the ZYA2 bin is 24.265 instead of 30. Should this be changed or is it supposed to be different? Also should the FN072 Patch and the FN1360b patches be applied?
Re: ZYA2 K-Constant
Yeah that's the stock value.
It should be changed but when doing so all of the SP** parameters will need to be updated. The fuel write up has the specifics.
those patches are up to you the tuner to decide. Read my comments for each patch so you know what al it does.
